Spark plugs
hey everyone, i want to put new spark plugs in but have never done it, and dont really if what if im right about what spot there in. i have a 01 4.8 V8 any advise pic or videos you could give me..thanks
yes i have "prior knowledge" but i have never done a change on a fuel injected car and it seems like a pain in the *** to get to and replace..do you have any advise you could give me so i dont screw anything up ??
I suppose you mean 4.7 but anyways you will need sockets to remove the stock air hat and the part running to the air box, then I think its a 10mm for the nut on top of the coil packs. They then pull out and you will need an extension and a spark plug socket. Not that hard at all just take your time. When you put the new ones in put anti seize on the threads and get them started by hand so you don't cross thread them. I suggest NGK V-powers.
No they wont get stuck and actually I never had a problem with them in the 150s anyway. You cant really mess anything up its a fairly easy job.
Trending Topics
yea i no it should be easy iv done it before, but they where fuel injected..and i work at ford and they say every time they replace spark plugs in the 150's like 2004 and up the spark plugs crack..and only ford has the tool to get them out haha
autolites or ngk
Well only had 02 and 97 f150's. another reason not to buy a new ford lol(i wouldnt buy one newer than 04 anyway)
