sonnax electric line booster
Old Apr 12, 2011 | 03:20 AM
moparman_2004's Avatar
moparman_2004
ok so i take it the power wire is just a extention
Old Apr 12, 2011 | 11:14 AM
thunder98110's Avatar
thunder98110
no. the sonnax is the 55 dollar thing. the 2 other pictures to the left of that are one of thoes "other customers also bought..." things. the power wire is different than sonnax.
Old Apr 12, 2011 | 12:49 PM
moparman_2004
ok i get that the sonnax is something diffrent so what do the power wires do
Old Apr 12, 2011 | 03:24 PM
thunder98110
fools pcm to thinking its 20 degrees cooler than what the iat reads.= dumps more fuel and advances timing for more hp
Old Apr 12, 2011 | 05:23 PM
moparman_2004
ok so this would be the same idea as putting a resister in the plug well looks like ill be ordering that too the resister set up never worked right i measured the resistance of the plug cold and found a resister the same value and tryed that but the ecm would never read it
Old Apr 12, 2011 | 07:18 PM
Blaze10's Avatar
Blaze10
where does the sonnax plug into?
Old Apr 12, 2011 | 07:25 PM
thunder98110
it plugs into the stock wire connector. get underneath and look on the passanger side trans. there will be a heat shield that you bend back to expose the connector. its the only connector. you cant miss it. stock exactly like the picture posted on the airram.
Old Apr 12, 2011 | 09:31 PM
Blaze10's Avatar
Blaze10
do i have to run wires or anything or i just plug it in
Old Apr 12, 2011 | 09:33 PM
thunder98110
plug it in to the existing thing. 5min job. theres a red clip that holds the connectors together that you have to slide the red tab to be able to pull it apart and push to gether to lock it.
Old Apr 12, 2011 | 09:36 PM
Blaze10's Avatar
Blaze10
oh ok, so pretty much if i cant do it i shouldnt touch a wrench lol
