That makes sense. It's pretty much fact that they won't do anything unless you have a need for them, but if you're running HO cams and intake I could see them helping. I suppose the spray mignt effect how effcienctly the burn is.
I'd like to know what you plan to accomplish by putting larger injectors in an otherwise stock engine. 39lb injectors will support over 500hp NA and 450HP with FI. The stockers should support around 300HP.
once i get it tuned with hemifever you will retract that statement. do you even know whats in an HO. normal accel injectors are pretty much stock its a WOT when its much different.
I will not retract my statement. The stock HO is 265hp. From my research the stock injectors are 23.8lb/hr. Those are good for about 325HP, I have a hard time believing you're making more than that, and if you are I don't see why the duty cycle can't be stretched a little in the tune. You certainly don't need 39lb injectors, 30lb at most.
