Baffled
Old Apr 23, 2011 | 03:22 AM
Rakaric's Avatar
Rakaric
When the forward (pre-cat) sensor is not functioning, the PCM will go into open loop, which basically means it's going to get the A/F mix from a pre-set parameter table programmed into the PCM. This usually will mean a richer mix than when in closed loop as the PCM "thinks" the vehicle is warming up.
Okay...so I'm guessing the PCM is misinterpreting something then? Now I'm not the original owner, but what if the previous owner used some kind of superchips to tell the computer to run in an economy mode. I'm assuming that adjusts the A/F? Just a thought..(since I can't explain this phenomenon)...what if the computer has those settings configured, and the O2 circuit overrode those settings? I don't know how those programmers work on a long-term basis, so I'm just curious.
Heck, if I'm getting better MPG, screw these things...I'll just get a simulator to eliminate the CEL.
Old Apr 23, 2011 | 09:15 PM
ryan_brown33's Avatar
ryan_brown33
so what would happen if you were to put a fake O2 sensor or whatever they are called in place of the pre-cat sensors? sorry for all the questions haha
Old Apr 25, 2011 | 05:43 PM
ryan_brown33
anyone?
Old Apr 25, 2011 | 06:50 PM
Pwall's Avatar
Pwall
it would throw a code the sensors need to read a difference from the pre cat to the post cat to prove that the cat is working
Old Apr 25, 2011 | 11:10 PM
ryan_brown33
ok thanks for the explanation
