how do i get my check engine light to turn and stay off, nothing is wrong with my engine or truck for that matter..its just becasue of all the miles..can anybody help me
Do you know how to check for the code? It doesn't just come on because of certain mileage, it comes on because something it's just right. Turn your key to the on position (not actually starting the truck) then off, then on, off, on, off. Three times. Then a code will display in the odometer. Either look it up or let us know what it is and we'll tell you the problem. It's probably something minor but it should be attened to.
Or visit any auto parts store and borrow their code reader, all you need is a drivers license or credit card as collateral until you bring it back. you can clear the code with a code reader too
You can clear the codes by removing the negative battery cable and turning the ignition on for 20 seconds. But if there is a problem the code will just come back. You will be better off just fixing the problem as others have said.
unless you know someone that is good with computers and owns a motus whom is willing to shut the monitors off in the computer. your going to have to fix the issue. weather it be a cat and o2 sensor or an evap leak. most of the time the fix is easy
thanks for all the tip...i work at a FORD dealership so i "borrowed" a code reader found out that it was the power steering sensor. so i ordered a new one and cleared the code.
