Truck occasionally dies when stopping
Old 05-25-2011 | 12:36 PM
tinmanchris's Avatar
tinmanchris
Thanks guys for all the suggestions. The good/bad news is that replacing the IAC valve helped quite a bit (the RPM doesn't dip as low) but it's still dipping down when going to reverse or when stopping. And yes I did clear out the PCM memory before starting up the truck.
I'll drive more the next few days to get a better feel as I only got to drive it 6 miles yesterday; it hasn't stalled yet which is a nice improvement.
Possible fixes I'm hoping is to replace the TPS sensor, or reprogram the PCM.
The battery is less than a year old, I replaced it around Dec. as it was corroding.
  #22
Old 05-25-2011 | 12:37 PM
tinmanchris
Originally Posted by McNasy
my 4.7 idles around 550-600
Thanks for that info! You have just confirmed that at least my 4.7 idles at the same range.
  #23
Old 05-26-2011 | 12:35 PM
tinmanchris
Drove it a bit more this morning. So far there is a huge improvement however the issue isn't completely gone, the idle still wavers a lot when stopping or going in reverse. Next stop is to order a new TPS.
  #24
Old 05-26-2011 | 03:57 PM
McNasy's Avatar
McNasy
every once in a while when i come to a stop, my idle will dip into the 400 rpm range. it sounds like mine is taking the same path as yours, as in it almost dies. the cool thing is when its idling at 425ish, it sounds cool as hell, sounds like it has a huge cam in it.
  #25
Old 05-26-2011 | 11:17 PM
jb1976's Avatar
jb1976
well i had somewhat same problem. 2000 dakota 4x4 5speed 4.7 v8. everytime i would stop it would die. no check engine light until later. but when i replaced 2 oxy sensors it still didnt help and finaly the last one replaced finally helped it out. i had to replace the speed sensor on the rear diff.it would always die when slowing down or when i turned the steering wheel.hope this helps you out.
  #26
Old 05-26-2011 | 11:25 PM
jb1976's Avatar
jb1976
problem cleared up in 5 mins with new speed sensor..see if thats works. only $35
  #27
Old 05-27-2011 | 01:45 PM
tinmanchris
Thanks. I'll keep that in mind. My truck stalled out yesterday again but it was the first time in a few days.
The TPS comes in next week so I'll replace that and see what happens.
  #28
Old 05-31-2011 | 11:49 PM
tinmanchris
Installed the new TPS and there is no change with the issue.
I've added two videos to youtube for people to see what the issue is like:
http://www.youtube.com/watch?v=7B4NtPIRw2g
http://www.youtube.com/watch?v=x6WP_-qvha8
In these videos I jam the RPM decently high, then come to a complete stop suddenly. Where you see the drop is actually when the car has that snap back effect when stopping quickly. Hopefully this insight will give new ideas to solve this issue.
Deciding what to do next...
  #29
Old 05-31-2011 | 11:54 PM
samnbensdad's Avatar
samnbensdad
Did you reset the PCM?
  #30
Old 06-01-2011 | 01:21 PM
tinmanchris
I did for the IAC, haven't done it yet for the PCM. Will reset it and try again.
