Please help with my lift
Old May 21, 2011 | 04:44 PM
Trent479's Avatar
Trent479
Exclamation Please help with my lift
Its a 01 3.9 2wd. . . .if i get this http://www.4wheelparts.com/Lift-Kits...t_pn=FABKIT322 would i be able to put one inch spacers in there for more lift in the front? i want the truck to be raked and if i do this i will get a bit of rake! let me know what yall think!
Old May 21, 2011 | 11:46 PM
dirtbiker's Avatar
dirtbiker
Yeah you probably could. But I wouldnt spend a grand on this kit, when an identical kit is available for like $400. I have been looking at it, but don't think I want it i'm just gonna do the lift coils. http://www.doetsch-shocks.com/17.asp
Old May 22, 2011 | 01:31 AM
Trent479's Avatar
Trent479
wow thank you so much! my buddy actually mentioned this kit but i couldnt remember the name! thanks a lot! i will definantly research more with the spacers! thanks a lot man!
Old May 22, 2011 | 12:59 PM
dirtbiker's Avatar
dirtbiker
Yeah no problem. I think you gotta call to order though. I have a hard time believing the dak in the picture is a 2wd, or if it is, it is lifted more than just their 3 inch kit. If i knew mine would look like that (except I don't like the way the back looks so low), I'd buy it right now. You also need different wheels, with different backspacing. Stock ones won't work.
Edit: Stock wheels will work, but you need spacers if you want to run them. If i were to go with this kit, i'd get some cragar soft 8's.
Old May 22, 2011 | 01:57 PM
Trent479's Avatar
Trent479
yeah that truck is huge in the picture! i prolly has more then the 3 inch lift on it! yeah i will prolly end up gettin this kit once i get the money! and yeah i will be gettin pro comp rock crawler wheels, 15x8. they have a 4.5 backspacing, will that work?
Old May 22, 2011 | 04:06 PM
dirtbiker's Avatar
dirtbiker
Well it says on the page that the wheel can have a max backspacing of 4 and 5/8 of an inch. So yes, the wheels will work if they have a 4.5 inch backspacing.
Old May 22, 2011 | 04:15 PM
Trent479's Avatar
Trent479
okay i didnt even see that till after i posted that! thanks a lot man!!
cheers!!
