"pop" sound, right front, when turning
Old May 25, 2011 | 03:24 PM
whutee's Avatar
whutee
Default "pop" sound, right front, when turning
Have 2001 Dakota, bought used, and it makes a "popping" sound sometimes,in the right front wheel area, when turning left especially. It may do it turning right also, but not as much. Any ideas? Thanks.
Old May 25, 2011 | 07:59 PM
frydaddy82's Avatar
frydaddy82
4x4 2x4? if its a 4wheel drive my first guess would be your half shaft is goin bad.
Old May 25, 2011 | 08:14 PM
samnbensdad's Avatar
samnbensdad
+1 Frydaddy... Half shaft (aka CV axle). Typically the right axle will make the most noise when turning left.
Old May 25, 2011 | 09:24 PM
NickCornell's Avatar
NickCornell
Ball joints perhaps? I know on my dads truck one collapsed and it popped when turning
Old May 25, 2011 | 09:42 PM
thunder98110's Avatar
thunder98110
tie rod end?
Old May 25, 2011 | 10:17 PM
dodgeramguy85's Avatar
dodgeramguy85
Could be cv joint,tie rod ends,ball joints or bad bearing. Mine did the same when my hub bearing went but it was pretty bad.
Old May 26, 2011 | 12:05 PM
sl2racer's Avatar
sl2racer
need more info
Old May 26, 2011 | 02:46 PM
whutee's Avatar
whutee
yes you were right. It was the ball joint. Thanks to everyone.
Old May 26, 2011 | 09:37 PM
frydaddy82's Avatar
frydaddy82
ah yes nothin like a dakota with a bad ball joint. good luck man
