obd code p0320
Old May 29, 2011 | 02:05 PM
mywifeknows everything's Avatar
Default obd code p0320
My 2001 Dakota 4.7 4wd was bucking a little bit and the check engine light came on i checked the computer with an ODB tester and came back with a po320 code any ideas on what it can be.
Old May 29, 2011 | 02:39 PM
thunder98110's Avatar
thunder98110
no crank reference signal registered by the pcm. probably your crank position sensor.
Old Jun 13, 2011 | 08:57 PM
3pedalsinmytruck's Avatar
3pedalsinmytruck
Have you asked your wife?
Old Nov 6, 2012 | 09:57 PM
Dodge94538's Avatar
Dodge94538
I have a 2002 Ram 1500 with a 4.7. I change the crankshaft sensor, the truck still ran rough, changed the spark plugs and notice that 3 of the coils had separated. Changed 4 of the coils, the truck ran good until it got warm. then it stopped, and would not start. Any suggestions.
