need quick pics of 2 & 3" lifts
ok i have to decide if i want 2" or 3" lift blocks before this wknd. installing new leafs and not sure how big to go. no offroading, not too big of tire, stock now, tow pop up trailer occationally. just figured id lift it up a little while im putting new leafs in. not sure if 3" will be too much.
Thanks
Thanks
Here's two pictures with two inch blocks in the back. Honestly I think you shouldn't put anything larger than two inch blocks unless you tow quite a bit.
One thing i've seen happen is ppl forget that when you add bigger tires that adds inches as well. So you add 2" in suspension and then like anyother 2-3" in tires.
A bud of mine did a lift with big tires, the truck was a beast-and-a-half and he cant really tow his trailer anymore.
yeah i ended up going with 1" blocks. with the 5/8 or so shorter shackles and helper springs i'll prob have 2" or so. it only looks a little higher than the front which is what i wanted so im happy. thanks for help.
