B&M Transmission Cooler/Gauge.
Old Jun 6, 2011 | 08:38 PM
fourpointseven's Avatar
fourpointseven
Default B&M Transmission Cooler/Gauge.
I plan on ripping Out my AC condenser and components to install My trans cooler and Gauge. I have a couple questions...What line on the dakota radiator Is the return and Sender to the transmission?I Was planning on useing 3/8 High pressure Rubber lines and keep the stock cooler in. Trans-stock cooler, return line to Aftermarket cooler then to the transmission, which is correct.BUT, IF i plan on using the 3/8 high pressure rubber lines How can i Put the T-fitting in the return line IF the T-fitting only accepts Steel lines?...(For the trans gauge..)confused..
Old Jun 6, 2011 | 08:58 PM
fourpointseven
Another note, What size are the rubber Lines Entering and exiting the stock cooler, 3/8??.
Old Jun 8, 2011 | 04:45 PM
fourpointseven
Ttt... What's the location of the sender and reuturn lines of tranny oil?
