99 dakota 2.4 starting problems HELP
Old Jun 9, 2011 | 08:15 PM
icujohanna's Avatar
icujohanna
Angry 99 dakota 2.4 starting problems HELP
will turn over, but won't start. any help?
no power to the coil, no power to the pcm, no power to obd-2 plug, and all fuses and relays are good.
Old Jun 9, 2011 | 09:33 PM
g. man's Avatar
g. man
Could be the 3 to 1 splice under the power distribution box. There is a write up on it in the FAQ 1. I've had the same problem before, and never really figured it out. My problem wasn't the splice though. I ended up replacing the throttle position sensor, and idle air control. I would check your grounds also, and re-set your ECM by disconnecting the neg. battery cable and turning the key on (the spot before turning over the engine) for 20 sec. All I know is my truck is like a woman..... very temperamental. If it starts after re-setting the computer than you know it's a sensor, or something electrical. I'm a novice to these trucks though. Good Luck!
Edit: Check your CEL codes too. There is also a write up on this in the FAQ.
