cant get socket onto spark plug
Old Jun 18, 2011 | 12:06 PM
thepope's Avatar
thepope
Default cant get socket onto spark plug
I cant seam to figure this out I took out 3 of the spark plugs, and the other 3 the socket wont fit over. its like they some how got swollen? any one ever herd of this.
Old Jun 18, 2011 | 12:18 PM
spyknee's Avatar
spyknee
Did the spark plug wire come off cleanly? I pulled a wire and the metal contact pulled out of its boot, staying attached to plug. Making it longer. Since the metal heat sleeves were in, I did not notice untill the tool would not seat on the plug right, pulled the sleeve and pryed off the rest of the wire contact point.
Maybe?????????????????
Old Jun 20, 2011 | 02:26 PM
thepope's Avatar
thepope
I fought with it for some time. gave up put the plugs back in and took it to a shop. they said it would take 45 min of labor to change the plugs. but it ended up taking 5 hours of labor..... the guy who did it was not there. So I dont know y they were stuck so bad. I think its very possible that those were the original spark plugs.
Old Jun 20, 2011 | 05:57 PM
xX_Devious_Xx's Avatar
xX_Devious_Xx
Anytime ya change your plugs make sure you use that Anti-Seize, its only like a dollar or two but its well worth it. I had one break off on me and it took me FOREVER to get it out. Good Luck
Edit: Forgot to say if you do break it off like I did use an easy out on it. The ceramic and all came out of mine, that's why I was able to use an easy out on it. Good Luck Again
Old Jun 20, 2011 | 07:35 PM
bpark8824's Avatar
bpark8824
That's really weird, I would have liked to hear why they were so hard to get out, or why a socket wouldn't go over it...
How many miles on the truck? 3.9 v6 I assume?
