rear speaker install
Old Jun 24, 2011 | 11:19 AM
mazz3242's Avatar
mazz3242
Default rear speaker install
i have an 01 extended cab...how do i get to the rear speakers
Old Jun 24, 2011 | 11:24 AM
thunder98110's Avatar
thunder98110
its a huge PITA, gotta remove the seatbelt, then that whole panel is held in by chrismastree clip things. took me like 6hrs to do both of them.
Old Jun 24, 2011 | 11:32 AM
thunder98110
Not from me but from 01silver "Jimmy" all credit goes to him
1. Slide both front seats all the way forward, seat backs let forward too. Pull straight out on the back rest part of the back seat, working from one of the bottom corners and going across the back side of the cab. Unsnap the bottom edge first then work up and snap the top side out. It has about a dozen plastic snap-in retainers. If one breaks don't worry, you can buy new ones cheap at any good parts store. Remove the cushion from the cab and put it in the bed or some other place.
2. Flip the rear seat bottoms up and remove the 5 or 6 10mm bolts holding the storage and tool tray in place. Renove the jack and jack tool bag, then remove the tool tray from the cab and put it somewhere out of the way too.
3. Remove the front right and left kick panels. Pull straight back on the edge of it that covers the door jamb and it will snap right out. Then pull up on the door sill cover panels and put all the pieces out of the way somewhere.
4. Snap the cover off the upper seat belt anchors and remove the torx bolt there, I think it's a T45 or T50. Let the seat belt rest in the rear floorboard.
5. Open the rear side window.
6. The rear side panel is actually made up of two separate panels, one on top and one on bottom. Reach up on the top rear corner of the upper plastic panel that is covering the rear side window, closest to the back windshield, and feel the metal snap in fastener just behind that corner of the panel. Get your index finger on one side of it and middle finger on the other side of it and snap the corner loose. It is best to do it that way to keep from cracking the panel. There are 2 or 3 more metal fasteners just like it on the back of the upper panel, and remove them the same way. Then pull the top section out and pull the lower edge of the upper panel away from the lower plastic side panel (the one with the speaker grille on it).
7. After that, you will see a couple of phillips head screws on the top and back edges of the lower panel, and I think there may be one or two screws on the bottom edge too. Remove all the screws, then work the panel out from around the seat belt and just let it rest on the ground outside the door. Put down some cardboard or a blanket to keep it from being scratched.
8. Then you should be able to just remove the 3 philips screws holding the speaker to the side panel.
9. Follow these steps in reverse to reassemble everything.
In case you need to know, on the left rear speaker the brown/yellow wire is positive. I think the negative is brown/light blue on that side. On the rght rear speaker, the blue/white is positive and the negative I think is blue/orange. It has been a while but I think those are your colors.
You can either separate the factory speaker from its plastic mounting bracket and screw the new speakers to them, or use the old speaker as a template and make your own mounting brackets out of 1/2" medium density fiberboard. You can get a sheet of mdf big enough for both speakers for about 5 bucks at Home Depot in the shelving area of the lumber department. If you use mdf panels, paint them with flat black spray paint first so you can't see the mdf through the speaker grilles. I have always just made my own speaker adaptor plates from mdf, and I think it sounds a lot better and has less resonance than using plastic adapter plates, but either way will work. It's also a good idea to line the inside edge of the rear speaker locations with a layer of duct tape, you don't want to go through this whole process again just because a speaker terminal is touching metal behind the speaker hole and grounding out the radio or amplifier.
Jimmy
Old Jun 25, 2011 | 12:57 AM
jondakotaguy's Avatar
jondakotaguy
Do your self a favor and dont use any cheap adapters.. get some plywood and make your own mount..
I busted the plastic ones and now my rear speakers rattle.. and i gotta rip it all apart again.. thats after i remove a 150LB subwoofer box... cus I'm lazy and wont take the subs out first.. LOL!
Old Jun 27, 2011 | 11:18 AM
mazz3242's Avatar
mazz3242
im not doin any subs i aint into rap **** haha, nah im just doin the regular speakers
