Brake prob
Old Jun 28, 2011 | 12:23 PM
willardg's Avatar
willardg
Default Brake prob
I just replaced front disc pads/rotor, rear break shoes and (of course) pedal goes to floor when engine running,and there's a hissing noise (inside cab,floor board around brake pedal, like a air leak)) I did bleed the brakes, and when engine is OFF, there is little play(in pedal) but when engine on pedal goes to the floor. Did I mess up something in the process? thinking maybe its the "power brake booster"?
master cyl seems OK, since it will pump fluid, when I bleed brakes
2001 /std 2 dr cab , 6 cyl,
Old Jun 28, 2011 | 10:13 PM
NickCornell's Avatar
NickCornell
So you properly bled the brakes right??
Old Jun 29, 2011 | 12:30 AM
willardg's Avatar
willardg
yep, but I'm gonna do it again with engine runnin, Read somewhere that works
Old Jun 29, 2011 | 09:47 AM
NickCornell
I've always dont it that way. Try it for sure while its running
Old Jun 29, 2011 | 06:20 PM
dolittle's Avatar
dolittle
Did you adjust the rear brakes?
Old Jun 29, 2011 | 08:04 PM
NickCornell
Nope just new pads
Old Jul 1, 2011 | 10:14 PM
willardg's Avatar
willardg
Talking
I replaced front disc pads/rotor, and rear brake shoes. I bled lines while engine running, and all is good now, Thanks for replies
