Starting problems
Old Jul 3, 2011 | 11:36 PM
Xxaler's Avatar
Xxaler
Default Starting problems
Video will explain more, despite it being far more rare and actually starting within 4-5 seconds compared to 6-8 seconds of cranking.
I've replaced the battery, replaced the starter motor, fuel pump and lines are still in nearly new condition, tried turning it on until the fuel pump was done priming multiple times before starting, but none of it seems to work.
EVERY time, it will crank for 4-6 seconds, then if I let off and crank again, it starts immediately. If I don't do the second crank within a minute or two it will revert to the original condition.
http://www.youtube.com/watch?v=DFeeZpWlQjw
Anyone had similar issues?
Old Jul 3, 2011 | 11:40 PM
thunder98110's Avatar
thunder98110
crank position sensor probably since you already replaced the other major stuff.
Old Jul 5, 2011 | 11:12 PM
Xxaler's Avatar
Xxaler
CPS replaced, and $40 down the drain.
Any other ideas?
Old Jul 5, 2011 | 11:17 PM
thunder98110
time for a new engine? the stuff you replaced would be everything i can think of.
Old Jul 22, 2015 | 09:59 PM
harkdodge's Avatar
harkdodge
Just wondering if you ever found out what the problem was with your intermittent starting problem. I have a 2001 Dakota that is doing the same thing.
Old Jul 23, 2015 | 08:00 AM
Robertwav1's Avatar
Robertwav1
EVERY time, it will crank for 4-6 seconds, then if I let off and crank again, it starts immediately. If I don't do the second crank within a minute or two it will revert to the original condition. Couldn't get the video?
Sounds like unwanted fuel in the cylinders. Any black smoke when it does start? This would be an indication of gas in the cylinders when starting. Leaking fuel injector or injectors maybe. Fuel pump regulator but you've already replaced the fuel pump which I assume has a built in regulator. Check for the smoke.
Old Jul 24, 2015 | 06:53 PM
brink5's Avatar
brink5
Sounds like a leaking fuel injector or fuel injectors. Just fought the problem you described on my 4.7l. Ended up being a slightly leaking injector on #8 cylinder.
