Fault code
Old Jul 8, 2011 | 11:03 AM
Rodester5's Avatar
Rodester5
Default Fault code
Hi, I have a question for you. The engine light came on, I plugged in the code reader and reset the light, everything seems fine. The code was P1197 "02 sensor slow". What dose that mean and what do I need to do about it?
Thanks.
Old Jul 11, 2011 | 07:59 PM
ritualjman's Avatar
ritualjman
It's gunna be a downstream O2 issue. Might just be an issue that requires the sensor to be replaced, though a diagnositic procedure is defined for this situation. I'd try unpluging both the rear sensors, putting some electrical connector grease in them and reconnecting them.
Old Jul 12, 2011 | 09:29 AM
Rodester5's Avatar
Rodester5
That's great, thanks.
Old Jul 12, 2011 | 09:34 AM
McNasy's Avatar
McNasy
just for my own notes, what year and engine do you have?
Old Jul 12, 2011 | 12:57 PM
Rodester5's Avatar
Rodester5
Mine is registered as a 99, 5.9ltr V8, Procharger P1SC, intercooler, methanol injection system, Aeromotive FMU.
It's a single cab, blue like your pic but with silver SuperBee stripes down the back end.
I was told it is capable of 800bhp with boost at 30psi and meth at 60%.
I have a dyno print out for 530hp boost at 15psi meth at 30%.
It has done the 1/4 mile in 11.24
It is running at around 6psi now and I dont know how to wake it up.
