P0500 fault code
P0500 fault code
First off, Truck is a 5.2L v8 with 5 speed standard, I killed the rear diff about a month ago, I swapped in one out of a 2000, Which came out of a truck with a automatic. First month no problems all is good, Then I start to have park brake and ABS light on every once in a while, Now its on all the time, So I pulled it out to see if it had metal on it if diff was shot, Nope all clean. So put it back in and now I got no speedo and truck stalls everytime I push clutch in to downshift slowing down to a red light, Does this seem normal for a speed sensor fault code? Should it be stalling with it or do I have another problem?
Thanks in advance
Thanks in advance
