gasket questions
Old Jul 15, 2011 | 11:13 AM
moparman_2004's Avatar
moparman_2004
Default gasket questions
i got a complete gasket kit for $30 shipped its a eristic and didnt realize the one i bid on was a 99-03 so whats the diffrence from 03 to 04 i cant see much of a diffrence but does anybody know
Old Jul 15, 2011 | 11:45 PM
moparman_2004
comon somebody has to know something
Old Jul 15, 2011 | 11:52 PM
thunder98110's Avatar
thunder98110
not a clue man, but i would feel more comfortable using the recommended year though. call the dealer, they might know.
Old Jul 16, 2011 | 12:00 AM
01blackdak's Avatar
01blackdak
Possibly changes to the engine I'd Imagine, just cause everything else 97-04 on dakota's generally fit all years in some cases.
But that is rather odd 99-03, but then again valve covers were changed is one of the obvious changes.
Old Jul 16, 2011 | 02:34 AM
moparman_2004
alot of the other parts are 98-02 then 03 and up and theres a 80 bucks diffrece in the sets but im sure i can use some of them cause last i checked valve cover gaskets were 23 so if thats alll i can use oh well
Old Jul 16, 2011 | 08:58 AM
moparman_2004
ok doing some cross refrencing on rock auto on the gaskets between the 03 and 04 4.7l i found 90% interchange and only have found two gaskets that are diffrent all the following are the same these are the ones i looked up
crank main bearing seal kit
rear main seal
head gaskets
intake manifold gaskets
valve stem seals
oil pan gasket
exhaust manifold
oil filler housing
water pump gasket
now the diffrences i found were these two
valve cover gaskets probley due to the change from magnesium to plastic my guess they changed the design of the gasket so if i use a set of 03 and earlier valve covers on a 04 which set do i use
timing cover gasket set looking at this there was a few designs to the timing cover set one using a flat gasket and one using the rubber seal style and a diffrence in the price has been found behind the two gaskets listed http://www.rockauto.com/catalog/x,ca...,parttype,5484
but then found this so he11 if i know http://cgi.ebay.com/ebaymotors/Dodge...item415b5c1d77
