Need stock air hat
Old Jul 16, 2011 | 12:15 PM
jondakotaguy's Avatar
jondakotaguy
Default Need stock air hat
Need a stock air hat anyone have one for cheap? I'm calling around junk yards but they want way to much money for one.
Old Jul 16, 2011 | 12:35 PM
moparman_2004's Avatar
moparman_2004
im sure somebody does that did a cai what happen to yours
Old Jul 16, 2011 | 07:30 PM
jondakotaguy
There is a peace of flat plastic I presume stops the air from swirling in the air hat which would cause excess turbulence. I kinda broke it off not really thinking about what I was doing.. and most hats have this and I do think this is the reason.. so its causing a little bit of restriction vs when it was stock..
ROFL.
Old Jul 16, 2011 | 10:04 PM
MoparMan1991's Avatar
MoparMan1991
You want to put the stick hat on and you're worried about restriction? Just get rid of the thing and hook a flex pipe with some hose clamps to it. I did and it made it sound nicer.
Old Jul 17, 2011 | 05:05 AM
jondakotaguy
Honestly I do not see much of a difference from the stock air hat and the others like K&N version..
both are basically the same as far as i can tell* but have not really held one in my hand so that's an assumption.
When I'm out and doing something i want max flow.. I have a round filter.. thats the best..
I'm not a fan of so-called CAI... I like Hot Rod style Round open filters..
Old Jul 17, 2011 | 12:06 PM
NickCornell's Avatar
NickCornell
Couldn't agree more^
Old Jul 17, 2011 | 07:13 PM
MoparMan1991
An air hat is designed to muffle the intake air, quieting something usually restricts it too. Just take off the hat completely and run a pipe to where ever your filter is at. Do you have any pics of your setup?
Old Jul 17, 2011 | 11:49 PM
jondakotaguy
with stock intake and Spectre filter or Open Round intake filter?
Ill have to upload they are on my phone..
Old Jul 17, 2011 | 11:51 PM
jondakotaguy
And indeed it does.. but if you pop off everything but that air had and put a filter on the end of it.. its almost as loud as the open airfilter.. just more deep sound than the holo sound effect the round filter has..
Thats the only thing I'm not too thrilled with is it sounds like something is about to blow up when you go WOT.. ROFL>. But damn it sounds like a V12 under the hood.
