Truck temp while towing in heat, and reducing
Old Jul 22, 2011 | 12:31 AM
wewanaplay's Avatar
wewanaplay
I guess maybe it could be off but it does move from 0 and that still wouldnt explain why my heater runs cool during winter
Old Jul 22, 2011 | 12:47 AM
magnethead's Avatar
magnethead
I was having the same problem in winter, top hose would barely get warm. Course now it goes to the second line in stopped traffic. I never understood it either.
Old Jul 22, 2011 | 02:40 AM
BlueQC's Avatar
BlueQC
Tell me more on the HHR fan, A fellow down the road has one that he dropped a tree on (DOH!) I could probably get the fan for a decent price. Easy install?
Where should it be wired to? Thermostatically controlled???
I was thinking that once its wired a small indicator light that it is on.
Old Jul 22, 2011 | 08:23 AM
thunder98110's Avatar
thunder98110
do a search for hhr fan in the 3g dak section. all the info you need there.
Old Jul 24, 2011 | 12:25 PM
dbilik's Avatar
dbilik
There is no 180 degree thermostat for the 4.7 l engine per napa.
Old Jul 24, 2011 | 12:54 PM
thunder98110
you need to buy it for the 5.9. then drill a little hole.
Old Jul 30, 2011 | 12:01 AM
jondakotaguy's Avatar
jondakotaguy
As far as the heater not getting very warm.. do a back flush on the heater core.. that fixed my problem with my heat..
Even with the 180 stat and new fan clutch.. it climbs temps almost to 210... not quite though.. so the 180 is helping a bit.. I'm starting to wonder if i have a blown head gasket..
I was thinking about running power through a fused connection directly to the batter and when temps at idle start climbing having an on/off switch in the cab to manually turn it on..
Wonders if i could get away with stealing the fan off the wifes 2000 taurus.. :X ^_^
Old Aug 2, 2011 | 07:09 AM
dbilik's Avatar
dbilik
I installed the fan and 180 degree thermostat. Improved the temp at lower speeds, but on the highway the temp still rises to the same levels as before. Haven't towed yet, but I am sure it will go higher when I do.
So...do I change the temp sensor in case it is off? Which I am thinking it is ok.
Change the radiator? It is a few years old, maybe it has clogged up?
Old Aug 3, 2011 | 07:10 AM
dbilik's Avatar
dbilik
I got it all worked out. Changed out the radiator and the truck is running much cooler, and I think I am getting excellent gas milage without the mechanical fan in place.
Old Aug 3, 2011 | 08:49 AM
thunder98110
nice job!
