Can you see me now?
Old Aug 1, 2011 | 03:50 PM
magnethead's Avatar
magnethead
Originally Posted by bpark8824
The sad part is, with our stock headlight housings HIDs are not very efficient. A lot of the light is reflected away and you are only getting about half the potential of the HIDs. In order for HIDs to be 100% efficient you need special headlight housings similar to a projector. So just imagine how bright it would be if you had 55w HIDs that were actually being used efficiently...
Actually, I'm not complaining. The whole problem, is that with a dual filament bulb, when you hit the high beams, you lose your low beams. That's why I wired the HIDs on a rocker switch and put my halogen's on the stock wiring. I can have high beams and HID's at the same time, which should make the road 100% better to see.
Old Aug 2, 2011 | 12:43 AM
magnethead's Avatar
magnethead
Got everything wired up. I like it. With the headlights off, I think it kinda looks like a snake outline (think of the halogens as fangs). Flip it over, and reminds me kinda of a AC cobra with Prowler turn signals.
Old Aug 3, 2011 | 08:28 PM
magnethead's Avatar
magnethead
I'm probably going to crank the HID's up 2-3 turns.
