Check Engine Lite on here are the codes(Please Help)
Old Jul 28, 2011 | 06:56 PM
2000DakotaQuad's Avatar
2000DakotaQuad
Exclamation Check Engine Lite on here are the codes(Please Help)
My 2000 Dodge Dakota Quad Auto Trans is now very sluggish.
First code 1757
Definition
Govenor pressure above 3 psi at 0 mph
Explanation
detected vehicle not moving yet govenor
Possible Causes
internal trans failure
open or shorted circuit condition
Second Code 1762
Definition
Govenor pressure offset voltage too high or low
Explanation
detected voltage was out of sec for more then 3 sec
Possible Cause
open or short circuit condition
Is this a bad sensor????
Old Jul 28, 2011 | 08:33 PM
dodgeramguy85's Avatar
dodgeramguy85
See what gear you are pulling out from? Try 1st and 2nd. My moms grand cherokee did this and it was pulling out from 3rd we had the 1762 code and ended up having the trans shop do the governor pressure sensor and the governor pressure solenoid for 316.00 out the door. I was told its better to do both of them while they are in there. Cause they seem to fail together and if the other one isnt bad it wont be before long till the other one goes.
Old Jul 28, 2011 | 09:26 PM
2000DakotaQuad
Exclamation
now the truck is not shift seems to be stuck in first now before yes I would agree it seemed like it was pulling out in third
Old Jul 28, 2011 | 09:32 PM
dodgeramguy85
It needs to be shut off and sit for a little. The grand cherokee would do this if you started it up and got on it to hard it would get stuck in first. Most of the time I solved this by shutting it off and waiting about 2-3 min then restart and take off slowly
Old Jul 28, 2011 | 09:40 PM
NickCornell's Avatar
NickCornell
Have you Reset and clear PCM? Disconnect negative and turn to start for 30 seconds
Old Jul 29, 2011 | 03:21 PM
2000DakotaQuad
no I will take the negative battery terminal off and turn the key to on for 30 sec when I get home after 5pm est
Old Jul 29, 2011 | 06:45 PM
2000DakotaQuad
Exclamation
ok i took the negative battery terminal off and put the key in the one position for 30 sec + The sevice engine light is still on but now the truck is back to sluggish start from stop like its starting in second or third gear. What should I do next. Should I replace the govenor pressure sensor and selenoid. I have called around and no one knows what these two parts are. are they called something else?
