Exhaust manifold flange
Old Jul 30, 2011 | 01:11 PM
wizard71jp's Avatar
wizard71jp
Default Exhaust manifold flange
Does anyone know what size bolts I need for connecting manifold to flange on a 99 3.9L v6?
and how much trouble is it? Tnx!
Old Jul 30, 2011 | 02:08 PM
1986JEEP's Avatar
1986JEEP
When i did mine i used 3/8". The hard part is geting the old ones out.
Old Aug 1, 2011 | 11:24 PM
moe7404's Avatar
moe7404
be sure and use anti-seize compound on ALL bolts on the bottom of your truck. dont forget brake tubing nuts
Old Aug 3, 2011 | 12:07 PM
wizard71jp's Avatar
wizard71jp
tnx guys! I'll try to get them out this next wkend...
How LONG are bolts do I need? I'm guessing about 2.0 in to 2.5 in??? and do they have special head???
Old Aug 3, 2011 | 12:36 PM
dodgeramguy85's Avatar
dodgeramguy85
I just did mine on my truck and it was a pain in the *** untill I took off my tire and my plastic inner fender well then it became so much easier where I used my grinder to cut the bolts.
Old Aug 3, 2011 | 03:29 PM
moe7404's Avatar
moe7404
long time ago i had a slant six. i used 3/8 bolt on the flange, but they kept coming lose. i figured out the bolt should have been 7/16 dia. so if it comes lose check a truck that is stock.
Old Oct 8, 2018 | 01:32 PM
moparborn's Avatar
moparborn
Is it the stock manifolds that are rusting,or do you have headers on there now?
If the pipe rusted to that piont,it is only a matter of time till it all goes.
Plus you do not know how far up the pipe you will have to go to get to good metal.
I would just replace them.
