Alternator voltage output
Old Aug 14, 2011 | 06:22 PM
01SilverCC's Avatar
01SilverCC
Default Alternator voltage output
I am getting ready to go on about a 1200 mile road trip, up to Atlanta, over to South Carolina and back home again. I was checking over my truck today, looking for any potential problems before I hit the road. I checked my battery/alternator with the truck idling and no electrical accessories turned on I had 13.65 volts across the battery terminals. I turned on the AC full blast, high beams and driving lights, at idle I had 13.45 volts, rev the throttle by hand up to about 1500 RPM and I had 13.65 volts again. This tells me that my alternator is working OK. I think I would have a higher voltage reading from it though if it were a colder temperature outside. It was about 95 degrees today.
This is on my 3.9 with a 5-speed manual. 145,500 miles on it, I am still running my original Denso 117 amp alternator, and I put a Duralast Gold battery in my truck last summer. I am just wondering if anyone else has any different output from their alternator.
Thanks for any info here.
Jimmy
Old Aug 14, 2011 | 06:32 PM
magnethead's Avatar
magnethead
That's just fine for low speed. Ideally you want about 14.4, but that may not be until 20-2500 RPM. The computer will also back it off a little in the heat. I think you're fine.
Old Aug 14, 2011 | 08:42 PM
01SilverCC's Avatar
01SilverCC
Thanks. I think it is OK too, I was just wondering if anyone else had anything different from their alternator or electrical system. Today I checked mine and the rest of my truck too just to be sure everything was in good shape and working OK. I put in a new air filter, new pcv valve, new wiper blades, topped off my washer fluid, checked all my tire air pressures, including the spare, I changed my oil and manual transmission lube too. My truck is running great and shifting very smooth right now.
I don't run a lot of electrical accessories, just a JL Audio 300/4 amplifier, and I don't play my system loud very much at all, and even then it's only for one or two songs, then I turn it back down to a normal volume. I don't use my driving lights much either, but they are good to have when I need them.
Jimmy
