posi rear end?
Old Sep 1, 2011 | 07:03 PM
00daksport25's Avatar
00daksport25
Default posi rear end?
I currently have an open diff with a 3.92. How difficult would it be to make it a posi and which gears are best?
Old Sep 1, 2011 | 10:01 PM
thunder98110's Avatar
thunder98110
well its go to run you about 4-500 for an auburn lsd or yukon what ever brand you choose. and its going to be cheaper to go a head and get gears done at the same time, 4.10 or 4.56. the install is going to be about 800ish. gears 150ish and bearing kit runs another 100.
Old Sep 1, 2011 | 10:57 PM
00daksport25
That doesn't sound too bad. How difficult is it to do my self. I'm pretty handy and learn quick. Which would be better 4.10 or 4.56? I'm still new to gearing, but eager to learn. Thanks for all the help.
Old Sep 1, 2011 | 11:17 PM
Rakaric's Avatar
Rakaric
I think you need to take it to a shop to do it, since it has to be set in to a specific measurement since you're putting in a whole new carrier.
Old Sep 1, 2011 | 11:28 PM
thunder98110
yeah, setting backlash and those shims is that makes or break an install.
Old Sep 1, 2011 | 11:45 PM
00daksport25
That makes sense. I'll look around and find a good shop close by. Thanks for the info guys.
Old Sep 2, 2011 | 11:56 AM
DakCC4x4's Avatar
DakCC4x4
If you are a 4wd then you need matching gears both front and rear.
Old Sep 2, 2011 | 12:41 PM
thunder98110
the fronts are reverse cut.
Old Sep 2, 2011 | 01:06 PM
1986JEEP's Avatar
1986JEEP
Yes you match the gears if you do not it will bind when you putt in 4 wheel drive
Old Sep 2, 2011 | 03:25 PM
00daksport25
It's a 2wd so I don't have to worry about that. Also, do you guys know which transmission I have? I've got a 00 dak sport 2wd with the 2.5 in it.
