Blew motor finally...
Old Sep 4, 2011 | 10:27 AM
01KotaQuad's Avatar
01KotaQuad
Default Blew motor finally...
i found a new one, question is...
it's a 4.7 out of an 06 Ram, Tranny included as well as the computer and all electronics...mine is an 01 with 4.7, is it going to fit directly in place as my 4.7 setup did and what all would i have to change? hoping the trans isn't longer or anything like that.
Old Sep 4, 2011 | 10:36 AM
thunder98110's Avatar
thunder98110
not a direct swap, you need to swap out crank tone rings, which is a big job. better to find one with a JTEC pcm if you can stay away from ngc.
Old Sep 4, 2011 | 08:05 PM
URBANRDNECK's Avatar
URBANRDNECK
EGR (you will need a Block off plate)
Old Sep 4, 2011 | 08:10 PM
thunder98110
how did you blow it anyways? timing chain snap?
Old Sep 4, 2011 | 10:51 PM
01KotaQuad's Avatar
01KotaQuad
It needed a valve job that I didn't get to in time cuz of work, so I think it busted and threw a rod...metal in oil and water so it's a goner. The new motor came from am 06 ram and is same as mine and has everything with it including computer and trans...
Old Sep 4, 2011 | 11:01 PM
thunder98110
you need to swap tone rings or it wont start. well maybe not if you swap the computer. but why make more work for your self.
Old Sep 5, 2011 | 02:57 PM
01KotaQuad's Avatar
01KotaQuad
Cuz it's $750 for all of it lol
Old Sep 5, 2011 | 07:38 PM
chris1996's Avatar
chris1996
yes that was cheap
Old Sep 6, 2011 | 09:07 AM
01KotaQuad's Avatar
01KotaQuad
yup just sitting there unused
