99 Dakota timing
Old Sep 11, 2011 | 08:04 AM
Parch's Avatar
Parch
Default 99 Dakota timing
I got a 1999 dakota 5.2L, seems to ping lots under load and heavy acceleration. can you set the timing on this? i know the comp does but what about the base timing?
Old Sep 11, 2011 | 10:51 AM
Hahns5.2's Avatar
Hahns5.2
No, timing cannot be changed without a tuner. And that isn't the real cause of the problem. A blown plenum gasket is a likely culprit, and/or carbon build up. I've seen Seafoam do magical things when it comes to removing carbon buildup and stop pinging.
Old Sep 11, 2011 | 11:53 AM
dodgeramguy85's Avatar
dodgeramguy85
Hows your plugs?
Old Sep 11, 2011 | 06:46 PM
Parch's Avatar
Parch
Thanks
I will look at the plenum, plugs are new
do i add the seafoam to the oil or in the gas tank
i know you can do both with it
Old Sep 12, 2011 | 12:22 AM
Hahns5.2's Avatar
Hahns5.2
You introduce it into the intake via a vacuum hose.
Old Sep 12, 2011 | 08:51 AM
Parch's Avatar
Parch
thanks i will try it
Old Sep 12, 2011 | 05:53 PM
jondakotaguy's Avatar
jondakotaguy
Define "Pinging" Can someone give a noob a description other than hearing a pinging sound.. any other symptoms?
