99 dakota...wont start...
Old Sep 13, 2011 | 01:23 AM
njmason's Avatar
njmason
Default 99 dakota...wont start...
I drove my dakota to work... when i went to leave it would crank but not fire... i was low on gas but added some thinking i may have been out... i can hear the pump activating...i tryed adding fuel through the throtle body but still nothing
Old Sep 13, 2011 | 01:51 AM
magnethead's Avatar
magnethead
Did it at least try to chug or anything when you force-fed it fuel?
If not, sounds like coil doesn't want to fire.
Old Sep 13, 2011 | 02:00 AM
njmason's Avatar
njmason
Nope...just kept crankin
Old Sep 13, 2011 | 02:13 AM
magnethead's Avatar
magnethead
something electrical then. Any codes?
Old Sep 13, 2011 | 02:26 AM
njmason's Avatar
njmason
Checking tomorrow... a code tripped a few days ago then the light went off and hasnt came back on since
Old Sep 13, 2011 | 01:35 PM
njmason's Avatar
njmason
I have a cam pos sensor code and a throtle pos code
Old Sep 13, 2011 | 01:42 PM
URBANRDNECK's Avatar
URBANRDNECK
Yeahhh Its probably your cam sensor, that would fire the spark plugs at a different time than it should. Can you figure out which side of the engine the code is registered for? or does it just tell you that there is a problem?
Old Sep 13, 2011 | 03:15 PM
magnethead's Avatar
magnethead
Mason, what size motor is it? Like Urban said, it's probably the cam sensor, but the throttle position sensor probably isn't helping things.
I believe on the pushrod motors, the cam sensor is inside the distributor. Not sure where it is on the *.7 engine family.
Old Sep 13, 2011 | 03:37 PM
URBANRDNECK
In the .7 family it is in the front of head since its a SOHC Motor.
Old Sep 13, 2011 | 03:54 PM
magnethead's Avatar
magnethead
that's what I thought but wasn't sure.
