Bhp?
Old Oct 3, 2011 | 11:12 AM
Rodester5's Avatar
Rodester5
Default Bhp?
Hi all,
Dose any one know how much bhp a standard 98 R/T 5.9 makes?
How much could I add for a Procgarger at 8psi-ish?
If the bypass valve stays open, will it still produce boost, like 8psi, instead of 15psi?
Thanks.
Old Oct 3, 2011 | 11:24 AM
URBANRDNECK's Avatar
URBANRDNECK
It would be 250 HP stock and for supercharing it is about every 15 psi that your horsepower doubles with proper tuning, but you also have to take into effect that the supercharger sucks power from your engine as well with all the drag that it creates. so for 8 psi you would be looking at about a 40-55% HP increase. The valve would have to stay closed for more boost to build or a smaller pulley which would also increase the amount of boost you could produce. But if the valve opens at 8 psi, you could not make any more than that, so that is another way of regulating it.
Old Oct 3, 2011 | 02:42 PM
Rodester5's Avatar
Rodester5
Thanks Urban.
This is the reason I asked, it's a cut and paste of what it is ment to be:
DODGE DAKOTA PICK UP TRUCK 550+BHP, Automatic, Petrol, 1998 S Reg, 78000 miles, Blue. SUPERCHARGED DODGE DAKOTA 5.9 R/T V8 OWNED & BUILT BY A RENOWN HOTROD BUILDER & AMERICAN SUPERSTOCK CHAMPION.FULLY ROAD LEGAL!VERY RARE INTENSE BLUE PEARL.SPECS:P1SC PROCHARGER THIS IS HUGE METHANOL INJECTION SYSTEM. 318 RACE CAM. SHARLAND SHARP ROLLER ROCKERS. EDELBROCK TUBULAR MANIFOLDS. MAGNAFLOW EXHAUSTS. TWIN FACET RACE FUEL PUMPS. RUNS OVER 100PSI WHEN ON BOOST. 800BHP INTERCOOLER WITH CUSTOM INTAKE SCOOP. TAYLOR LEADS. MALLORY DISTRIBUTOR. AUTOMETER PHANTOM GAUGES. UPRATED SHIFT KIT IN THE GEARBOX FOR QUICKER SHIFTS. UPRATED REAR LSD. COMPETITION REAR AXLE. ANTI TWIST BARS. PROP SHAFT SAFTEY HOOP. HIGH FLOW SKAKER HOOD BONNET. UNMARKED CUSTOM ONE OFF BLUE/GREY LEATHER INTERIOR. GEARBOX AND DIFF OIL CHANGED AT THE SAME TIME. RUNNING 15PSI AND MADE 553BHP ON SHELL V POWER WITH METHANOL INJECTION includes dyno sheetsWITH A 30 PETROL/METHANOL MIX. THE PROCHARGER IS GOOD FOR 30PSI AND 825BHP. IT DID AN 11.24 SEC QUARTER AT YORK RACEWAY
I'm not reaching 15psi and not near 500bhp. Trying to work out where to start looking.
Old Oct 3, 2011 | 03:09 PM
URBANRDNECK
Well if you are trying to copy this ( I'm assuming this) where you could start first is making sure that you are getting enough fuel to your engine (upgrade your fuel pump). A methanol system is a good way to cool off your engine as well as increase your power. You should make sure though that your engine can handle the boost before you throw more PSI at it
Old Oct 3, 2011 | 04:04 PM
Rodester5's Avatar
Rodester5
No, not copying. That is what it is, it's all on there and done, It's not, or no longer, running at that spec.
I'm thinking 11.24 quarter is around 120mph over the line. I realy want to know that it will do it.
