1999 odge dakota sport vibration...help!!
Old Oct 10, 2011 | 10:22 PM
dodgedriverneedshelp's Avatar
Default 1999 odge dakota sport vibration...help!!
1999 dodge dakota sport. vibration at 100km but goes away at 120km. new ujoints and ball joints. took out front driveshaft and still has vibration. what else can i check?
Old Oct 10, 2011 | 11:57 PM
Senate427's Avatar
Senate427
How is the tread life on your tires? Are your rotors and brakes good?
Old Oct 11, 2011 | 10:08 AM
Tires are new are we thought that was the problem. Brakes and rotors changed as well
Old Oct 11, 2011 | 05:44 PM
dalejrfan88's Avatar
dalejrfan88
Check your rear u-joints.
Old Oct 11, 2011 | 08:22 PM
Hey... In my original post i mentioned I have new ujoints... Any other ideas?
Old Oct 12, 2011 | 12:27 AM
dodgeramguy85's Avatar
dodgeramguy85
Hub bearing could cause it but will also produce a grinding/whine noise. You sure none of the wheels threw a weight? (very unlikely but I did have it happen once)
Old Oct 28, 2011 | 02:39 PM
New 2 Dodge's Avatar
New 2 Dodge
http://arrc.epnet.com/autoapp/8960/8..._BALANCING.htm
Old Oct 28, 2011 | 02:52 PM
98DAKAZ's Avatar
98DAKAZ
Default serpentine belt
serpentine belt possible
I had a bad vibration going on it turned out to be my A/C bracket was badly cracked and vibrating like all hell check for loss or cracked A/C, power steering, or other things connected to the serpentine belt.
My vibration was noticed on acceleration mainly but Im sure it was vibrating all the time
