Liftin' That Rear!
Old Oct 16, 2011 | 11:53 PM
Krowbar's Avatar
Krowbar
Default Liftin' That Rear!
Gents,
Putting 3" blocks on the front coils of my 2000 2wd QC Dakota for a cheap lift....
What do you suggest I do to lift the rear to be as level as possible with the front...? Can just a "add-a-leaf" kit raise it enough to be completely level...? Or will I have to also get different shackles...? Leaf springs over axle swap? Whatever is the easiest/cheapest and will not sacrifice to much ride comfort. She IS a pavement pounder..
Thank you
Old Oct 17, 2011 | 01:17 PM
ahsnowlover's Avatar
ahsnowlover
I have a 99' and put a 2" lift on mine but my leaf springs sit on top of my rear axle so I just put a blocks in the back and tightened the front torsion bars. For my blocks total was like $100 with the blocks and new u-bolts. I personally think using blocks are the way to go for up to 4" after that I would do add a leaf especially since the blocks won't change how it rides
Old Oct 17, 2011 | 03:26 PM
Krowbar's Avatar
Krowbar
Yeah I have the 2wd which makes the leaf springs under the axle. I decided to just get some 2" shackles and hope that it will level out with the front. Do you guys know if I should have went with 3" shackles?
Thank you
