CTM Interchange
Well I finally upgraded and got a new truck. 2002 quad cab 4x4 4.7 Sport. Only problem is the previous owner switched out the CTM, and for whatever reason put in the base CTM on a fully loaded truck. I've been looking to replace it, but am unsure what years will work. So what years of Dakota's and possibly Durango's can I pull a highline CTM from and have it work? I know the keyless part won't work till it's programmed also.
Thanks.
Thanks.
I'm not sure of what will work but I can tell you what won't.
Anything older than 2001 will not work as Dodge changed the computer bus and they are not compatible, PCI (1 wire - new) versus CCD (2 wire - old).
