Doing some bolt on upgrades
Old Oct 19, 2011 | 04:43 PM
bluedodge23's Avatar
bluedodge23
Default Doing some bolt on upgrades
Hi, I own a 99 Dodge dakota with a 5.2 manual tranny. I'm doing some upgrades and wanted some input. I've already got my exhaust done. I went with a 2.5 to 3" exhuast with no cat. I put some shorty headers, with a 10" round air cleaner. I got some more parts but didnt get a chance to put them on yet. I need to change my pleneum gasket so while it's apart I'm going to do the kegger mod, and go with some 21# Ford injectors. I will also install a 52 mm throttle body. Everything in the motor is stock, will it be able to handle these upgrades for daily driving? I know I will have to upgrade my ECU but I was trying to get away with it until I catch up on my funds a little bit more. Then I will start playing with the motor.
Old Oct 19, 2011 | 04:51 PM
thunder98110's Avatar
thunder98110
i dont know what the stock # injectors the 5.2 has but dont go bigger untill you are able to tune it, otherwise you will run rich and have worse performance. on the subject of a tune, get a SCT tuner by Hemifever (hemifever@aol.com)
Old Oct 19, 2011 | 05:10 PM
moe7404's Avatar
moe7404
use anti-sieze compound on EVERY bolt. mostly on break tubing nuts, exhaust bolts, so on. later you'll me glad you did.
Old Oct 19, 2011 | 10:16 PM
NickCornell's Avatar
NickCornell
I also run an air cleaner, awesome isn't it? I recommend them to everyone with a vehicle haha
Old Oct 20, 2011 | 12:08 AM
dodgeramguy85's Avatar
dodgeramguy85
Sct is the way to go my 5.2 is so much better with it. I run mine on the 93 tune with 89 gas. It runs perfect.
Old Oct 20, 2011 | 09:05 AM
bluedodge23
I said I run a 10" air cleaner, instead of a factory air cleaner ... I didnt want to do all the bolt on upgrades then go with a SCT then mess with the motor(cams , pistons, heads ect.) and have to have another program flash.
Old Oct 20, 2011 | 10:28 AM
DakMan6704's Avatar
DakMan6704
He was being sarcastic...
Anyway, search around in past postings...youll find some good answers for your truck too..
Old Oct 20, 2011 | 11:59 AM
Hahns5.2's Avatar
Hahns5.2
Don't mess with the injectors.
