What's quicker 0-60 mph - 2hi or 4lo? (video inside)...
Old Oct 24, 2011 | 11:20 PM
Shomegrown's Avatar
Shomegrown
Default What's quicker 0-60 mph - 2hi or 4lo? (video inside)...
Take a guess then watch the video.
http://www.youtube.com/watch?v=uN9he2qrA9Y
Old Oct 24, 2011 | 11:30 PM
thunder98110's Avatar
thunder98110
im over .5 seconds quicker in 4hi, but launching in 4low is a terrible idea.
my best 2wd launch was 7.03, but usually around 7.2ish, in 4hi its sub 7 by a hair
Old Oct 25, 2011 | 01:34 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ouch! I would never take 4low to 60. Heck the owners manual says don't go above 25mph. Heck I wouldn't even dare to put it in 4low on the pavement yet alone gun it, too much torque and grip.
Old Oct 25, 2011 | 05:32 AM
Blaze10's Avatar
Blaze10
wtf... yeah i wouldnt either..
Old Oct 25, 2011 | 07:01 AM
DakMan6704's Avatar
DakMan6704
I have...by mistake...I think she tops out around 45-50...thats teh downside of electronic shifting...
Old Oct 25, 2011 | 12:01 PM
Shomegrown's Avatar
Shomegrown
It's just having a little fun...
If something breaks, it probably needed to be replaced anyway.
Old Oct 25, 2011 | 12:21 PM
bpark8824's Avatar
bpark8824
Using 4wd to launch your truck is just a bad idea in general. These 4wd systems were not built for that in anyway. You not even suppose to use 4wd on dry pavement let alone launching it. That's how you break stuff, and it can be expensive if you start breaking half shafts or ruining something in your diff or t-case.
Old Oct 25, 2011 | 12:34 PM
thunder98110
diesel guys do boosted launches in 4hi.
Old Oct 25, 2011 | 02:51 PM
Shomegrown's Avatar
Shomegrown
That's not exactly true. I didn't turn the steering wheel more than 1/2 turn while on the pavement so I wouldn't bind the driveline. That's really hard on it as you said.
When you're locked in 4lo, you're distributing the torque 50/50 front and rear. Even though you've got more torque available from the transfer case gear reduction, you split it nicely between the front and rear axle so neither axle gets overloaded.
In 2hi all the torque goes to the rear end, so that's just as hard (if not harder) on the rear than launching in 4lo.
The only part that really gets stressed in 4lo is the transfer case itself.
You're more likely to bust something off-roading in 4lo because when you lift wheels you can put 100% of the torque on a single axle.
Old Oct 25, 2011 | 02:53 PM
Shomegrown's Avatar
Shomegrown
Yep, seeing a 3 ton+ rig doing 4 seconds 0-60 off a brake boosted launch in 4x4 is just insane.
