Camshafts
Old Oct 25, 2011 | 12:32 PM
sideASS's Avatar
sideASS
Default Camshafts
Whats goin on guys. I have a 99 dodge dakota with an SCT tuner, and Afe stage II CAI. I just got about a $700 pay check and im buying a cam with it. I just dont really know what cam to get. Anybody know any good cams for my truck? Im really looking for a rough idle/chopey sound, or something close to that. Anything helps thanks!
Old Oct 25, 2011 | 01:33 PM
URBANRDNECK's Avatar
URBANRDNECK
Could you post what engine you have in your dakota?
Old Oct 25, 2011 | 06:23 PM
moe7404's Avatar
moe7404
if you need a street cam, that wont break the bank. limit the duration to 268 advertised not .05. and lift to .430 inches. note this is not a race cam, VERY street-able, will idle just like the mild cam. i had one in 1965 chrysler 300L 413 ci 360 hp. a new yorker, had 248 duration, lift .389, 430 hp, very mild. the 300L (4200 lbs) did the 1/4 mile in 16.08 sec. totally stock. my 300L got the same mpg as the new yorker. but MUCH faster. just my ldea.
Old Oct 27, 2011 | 07:43 PM
sideASS's Avatar
sideASS
Sorry its the 5.2L 318
Old Oct 27, 2011 | 08:35 PM
moe7404's Avatar
moe7404
the sizes of cam will work about the same on different engines. you could a little more than i listed bout not to much. i have no idea how that works on newer type engines, like the electronics.
Old Oct 28, 2011 | 12:49 PM
sideASS's Avatar
sideASS
alright appreciate it. I just want that rough sound like the thumpr cam from comp cams gives you.
Old Oct 29, 2011 | 12:35 PM
stogie300's Avatar
stogie300
if you go to www.hughesengines.com look at the whiplash cams for 318 that would be right what your lookin for i was lookin at them for my dodge 1500 318 you use everything stock heads an all just need to put there heavier valve springs in an that engine should come to life an have that aggressive lope
Old Oct 29, 2011 | 09:59 PM
moe7404's Avatar
moe7404
if the cam you chose makes it sound like rocks, you ll spend money at each pump you try to pass. if you like wasting money on gas you cant use on the street you will need to carry wheelbarrow to hold your money for the fuel. been there done that, not again.
Old Oct 31, 2011 | 01:17 PM
sideASS's Avatar
sideASS
well i dont think its possible to spend anymore money at the pump than i already do so that doesnt really matter to me lol
Old Oct 31, 2011 | 01:27 PM
sideASS's Avatar
sideASS
and stogie i looked at that cam but its for the LA engine and i have the magnum. Does that matter?
