What size tire can a fit?
Old Oct 29, 2011 | 04:25 PM
whtdkta's Avatar
whtdkta
Default What size tire can a fit?
Hello new to the forum, i have a 99 white dodge dakota 4x4 extended cab with the 5.2 in it. I need tires bad was wondering what size tire i could fit without to much rub? it has 31's on it right now i believe. thanks in advance
Old Oct 29, 2011 | 04:30 PM
chris1996's Avatar
chris1996
i have in mine 31s and is the biggest i would go without a lift
Old Oct 29, 2011 | 05:44 PM
Cali01dak's Avatar
Cali01dak
X2 on that. 31s I believe are the biggest you can go without a lift and without having too much rubbing as well
Old Oct 30, 2011 | 12:31 AM
Blaze10's Avatar
Blaze10
crank the tbars it's cheap an you can get 32s easy, but 31s are about it
Old Oct 30, 2011 | 03:39 AM
jondakotaguy's Avatar
jondakotaguy
I'm sure there is a guide on how to do this but my search is just not working.. ^_^
Old Oct 30, 2011 | 07:47 AM
Blaze10's Avatar
Blaze10
buy the torsion bar keys for like 50 bucks they come with instructions.. an youtube has videos on how to do it
Old Oct 30, 2011 | 12:13 PM
whtdkta's Avatar
whtdkta
does crankin the t bars affect the ride at all?
Old Oct 30, 2011 | 04:35 PM
chris1996's Avatar
chris1996
IDK i suppose it gets harder
Old Oct 30, 2011 | 04:57 PM
Cali01dak's Avatar
Cali01dak
I forgot about the tbars. Helps alittle bit
Old Oct 30, 2011 | 08:07 PM
Blaze10's Avatar
Blaze10
not really noticable. if you get blocks under the rear axle it will.
