Bad Fuel Pump?
Old 11-06-2011 | 08:06 PM
Yarnie's Avatar
Yarnie
Well, didnt quite fix it..but I did some reasearch, after noticing my air filter was filthy, could very well need a new air filter and plugs..haha....not even been a year since I had a new one on it...but oh well.
Old 11-06-2011 | 08:15 PM
Yarnie's Avatar
Yarnie
Dunno why it double posted..and so far apart sorry
Old 11-14-2011 | 04:05 PM
edgetoedge1's Avatar
edgetoedge1
I have been having the same problem. But I replaced the battery, spark plugs, spark plug wires, distributor cap, rotor button, pick up inside the distributor, coil and fuel pump. I am still having trouble with the truck starting. I am very confused. Also with my truck while I am driving the engine will shut off. I have all electrical power but not power to the engine. Then when I try to start my truck it will turn over but wont start. I have no clue what the problem is. I need help.
Old 11-15-2011 | 11:48 PM
huseman808's Avatar
huseman808
Crank position sensor?
Old 11-18-2011 | 02:08 PM
edgetoedge1
I checked the crank position sensor. It checked out good. Someone said check the tps. I pulled the plug on the sensor while the truck was running, they said if I pulled the plug on the sensor while the truck was running it should shut off if the tps sensor is working right. But when I did it stumbled for a second and just kept running. I was wondering if the truck should shut down if the tps sensor is not plugged in?
