Tire/wheel question
Old Nov 7, 2011 | 06:22 PM
Trent479's Avatar
Trent479
Default Tire/wheel question
quick question for yall. im gonne be lifting my truck, but i need new tires right now. and ima get tires to mount on my new wheels. i got these
http://www.4wheelparts.com/Wheels/52..._pn=PCW52-5868 and wanted to get 31x10.5 tires. . .could i get these in my stock hight truck? its an 01 3.9 2wd dak.
Old Nov 7, 2011 | 06:43 PM
chris1996's Avatar
chris1996
i think yes thats what ive read in the forum
Old Nov 7, 2011 | 07:18 PM
dirtbiker's Avatar
dirtbiker
Probably not without rub. You'll probably have quite a bit of rub. My tires are 265/70/16 and I get some rub at full turn, and mines lifted 2 inches all around, no real big deal. But if you're lifting it 3" or whatever, 31's should be fine.
Old Nov 7, 2011 | 09:01 PM
Blaze10's Avatar
Blaze10
youll be fine after lift
Old Nov 7, 2011 | 11:02 PM
ahsnowlover's Avatar
ahsnowlover
I don't know what the height difference between stock 2wd and a stock 4wd is but I had the 31 x10.50 on my stock 4wd and they never rubbed sitting at stock height. But if you are worried about rubbing your can do a 2" lift for pretty cheap, I just put 2" blocks in the back and tightened my torsion bars.
Old Nov 7, 2011 | 11:50 PM
Trent479's Avatar
Trent479
dang. . .yeah they will be dialed when its lifted with the 31's, but i need tires before i can lift it cuz mine are shot and its rainy season round here. . .crap! gotta put in some more overtime then!! hahah well worth it tho. thanks yall
Old Nov 8, 2011 | 07:08 AM
Missed Again's Avatar
Missed Again
As with Mr. Lover they fit fine on my ’00 4X4. Look in the owner’s manual, that’s what told me I could use.
Old Nov 8, 2011 | 02:24 PM
Krowbar's Avatar
Krowbar
2wd don't have torsion bars and you can't put blocks on them, unless you do a spring-over-axle swap. Get cheap coil spacers off of ebay for $110 and rear 2" shackles for the rear. I fit 275/55/R20's under mine with a little rub on the inside and I had to cute my front muper a few inches (really easy with dremmel and a dry-erase marker) Can you tell they are cut?
Also recently I put 1" wheel spacers on the front and they do not rub at all , but had to cut bumper a little more.. Look at picl. Mine is also a 2wd and sits about 2"s lower than a 4wd.
Old Nov 8, 2011 | 04:02 PM
Trent479's Avatar
Trent479
thanks for the help. was just tryna see if i can fit em stock before i get my lift, its on back order.
Old Nov 9, 2011 | 04:22 PM
Krowbar's Avatar
Krowbar
They will fit good enough to drive around. They will rub a little on the inside and might hit the bumper. Razor blade works better than a dremmel, won't heat up the plastic/paint and cause bubbles or anything in the paint.
