Antifreeze leak Need Help
I have a 2001 dodge dakota sport 3.9L
I looked at the raditator hose and there was no leak there so i ran my car a couple times around the block to see if i can get the leak to start up and i parked my car in the garage and i was under the car and it started leaking from i dont even know. does anyone have any ideas?
Thank you
Thank you
also check the heater hose going into the front of the block, on the water pump. There is a black tube that's bolted to the block with one bolt.Its sealed with a o-ring that drys out and under pressure it leaks. I just replaced mine that's how i know...
+1 on this, the pressure tester is the way to go, will make it a lot easier, and you don't have to work around scalding hot antifreeze
