03 Dodge dakota v6. 10mpg????
Ok i just got an 03 dodge dakota and so far ive been avg about 10 to 11 mpg on freeway/town driving from and to work, it has 150k miles, does that sound right?? or is there something wrong going on?
Something's definitely wrong. Start with the basics. Check or replace: spark plugs and wires, vacuum lines, maybe a fuel filter, cold be an O2 sensor, Maf sensor, Map sensor.... Ya know all the basics. haha
wrong tires? changed rear end gear? if those two are off you will will still be able to calculate mpg, it wil be wrong. sounds like the trouble iam having. but best not bore you about my trouble here. you may not know but these trucks do not use a gear on the transmission rear shaft. they have notched plate bolted to the ring gear. the notched plate sends a signal to the computer, that spins the speedometer . i have talked to half a dozen people, but iam not sure what to think.
