Tps?
Old Nov 17, 2011 | 01:33 PM
Ts610's Avatar
Ts610
Hmm. so maybe the sensor will take care of 2 issues at once. Couldnt get that lucky. lol
Old Nov 17, 2011 | 11:44 PM
NickCornell's Avatar
NickCornell
We have twin trucks, try tr tps, I changed mine with no trouble
Old Nov 18, 2011 | 09:06 AM
Ts610's Avatar
Ts610
Well changed the TPS and the shifting appears to be smoother but the lack of power is still there. I can stomp it at any speed and there is kick to it. Just slowly gains speed.
Old Nov 18, 2011 | 10:48 AM
Ts610's Avatar
Ts610
Went ahead and changed plugs will I was under there. Plugs were so frozen I had to use a bar on a few to break them loose. When I got them out someone had gapped the old ones to .075. According the the service manual they should be at .040. I put them at .040. Still lacking the power but seems to be getting better little by little.
Old Nov 18, 2011 | 11:35 AM
dodgeramguy85's Avatar
dodgeramguy85
With how cheap plugs are. Ill never re gap them I dont like to. Should of spent like 25-30.00 for plugs and called it a day. How is pulling out? Is it very sluggish or is pretty normal for a v6
Old Nov 18, 2011 | 08:40 PM
Ts610's Avatar
Ts610
Should have said that different. I didn't re-use the old ones. Meant I gapped new ones .040. It has not power. At any time I can stomp on it and the tach climbs but it slowly gains speed. Not sure what to check next. It is almost as if something is plugged up. Maybe Cat?
Old Nov 23, 2011 | 02:15 AM
chrisy1961's Avatar
chrisy1961
I also have the 2003 with the 3.9. Check your Distributor cap and rotor. Mine were original with 175,000 miles on them and they were ate up. I do not know how it even ran. I bought the Borg Warner from O'Reiley's and now she runs like a champ. Less that $20 if I remember right. Good luck.
Old Nov 23, 2011 | 07:08 AM
Ts610's Avatar
Ts610
That is what was the next thing I was going to change. I am hoping that helps. Strange thing about it is, I was leaving work yesterday and had to get on it and it kicked in. First time it has done it. Tried it again and nothing.
Old Nov 23, 2011 | 10:10 AM
mikeglass1969's Avatar
mikeglass1969
A bad TPS can throw a code. For example, my bad TPS cause p0201-208 error codes.
Old Nov 23, 2011 | 11:03 AM
Ts610's Avatar
Ts610
Yea changed to TPS.
