8k hids?
Old Nov 21, 2011 | 08:12 PM
URBANRDNECK's Avatar
URBANRDNECK
You can just call me Urban its shorter. Or Zack if you really wanna go the extra mile. But I just got them off ebay with my LED tail lights as a package deal
Old Nov 21, 2011 | 11:25 PM
Trent479's Avatar
Trent479
well thanks for all the links! yeah 55w is a lot, but ya know, i do alot of late nite drivin and i need to see! i work at 2 in the mornin so i use my headlights a lot to get to work. so a conversion kit in the clear headlights i posted will work out just fine?
Old Nov 21, 2011 | 11:27 PM
Trent479's Avatar
Trent479
http://www.ebay.com/itm/97-04-DODGE-...item4cfae5efcc these with these http://www.ebay.ca/itm/35W-12V-9007-...d=286928140919 but the 55w 8k version?
Old Nov 21, 2011 | 11:37 PM
dodgeramguy85's Avatar
dodgeramguy85
Yes it will work. Only thing I dont like about those cheap ebay kits is well cause they are cheap. I have installed 2 different kits from ebay and the ballasts are plastic and the connections dont fit as tight as they should. My kit was 60.00 but the connections are good and the ballasts are aluminum. I've had my headlights for 2 years and my fogs for a year. No problem with either of the kits.
Old Nov 21, 2011 | 11:41 PM
Trent479's Avatar
Trent479
okay sweet! thanks! yes definantly a quality factor when buying ebay stuff for cheap, i will definantly check the seals and grease/glue the connections. found the 55w kit that will fit high and low for my truck. . . http://www.ebay.com/itm/9007-8000K-5...item19ca7df42c gonne get this!
Old Nov 22, 2011 | 12:06 AM
dodgeramguy85
Dont forget to post up some pics!
Old Nov 22, 2011 | 12:10 AM
Trent479's Avatar
Trent479
always!! startin on the lift soon, its on back order but should ship soon lift then lights!
Old Nov 22, 2011 | 01:47 AM
cycodude's Avatar
cycodude
From: Live: Silverdale, WA; Work: WA, CA, VA, GA, FL; From: WV
I put these bulbs in my truck: http://www.ebay.com/itm/GENUINE-4350...ht_3767wt_1187
They're pure white (4350k) and bright as h@*l!!! In WA, it's illegal to aftermarked HID in a vehicle that wasn't made with them. I've been stopped 3 times now because they thought I had HID, so I guess they're bright enough!
