Vac Line / Leak Detection Pump
I had a recent vacuum leak from the hose that goes from the throttle body to the leak detection pump, I think thats what its called, the leak detection pump I am talking about sits under the fuse/relay block, I found the leak and replaced the hose, problem is now that the truck will not start unless I remove the hose then re-attach it when the truck is running, truck runs great when the line is removed then re-attached, just will not start with the line attached..
2002 Dodge Dakota 3.9 Club Cab
