removing a seat in a dakota
Old Dec 9, 2011 | 01:34 PM
mgaither0's Avatar
mgaither0
[IMG][/IMG]
[IMG][/IMG]
it has the regular bolts like these but then also has the rivets
Old Dec 9, 2011 | 02:27 PM
98DAKAZ's Avatar
98DAKAZ
Default I think
I think those are guide pins only not rivets just unbolt everything and see if they come out.
I think they will just unbolt for you
Old Dec 9, 2011 | 02:53 PM
mgaither0's Avatar
mgaither0
Its not guide pins. The reason I know that is I unbolted all the bolts in the seat and ricked it pull it pried it and all that happens is it won't come free where the center console/center seat are. Also in the front on the bracket under the seat it won't come free where the rivets are going through the frame. I even drilled out the rivets in the back and after that it was still hooked up where the frame has rivets through it into the bracket that connects into the the center seat.
Old Dec 9, 2011 | 04:12 PM
98DAKAZ's Avatar
98DAKAZ
Default odd truck
All I can say is you must have an odd ball truck
My truck dosent have those things
Old Dec 9, 2011 | 06:14 PM
mgaither0's Avatar
mgaither0
Did u look at the pictures? I know the dakota I tried to get the seats out of in the junkyard was a 99 also. Did 99 possibly have these and no one else
Old Dec 9, 2011 | 07:04 PM
mgaither0's Avatar
mgaither0
Is there a way to just remove the seat cousion?
Old Dec 9, 2011 | 09:11 PM
dodgeramguy85's Avatar
dodgeramguy85
You do not need to take the rivets out unless you want to completly remove the middle seat/consoul. To get the seats out the rivets do not need to come out it is easier to pull the whole seat assembly then dill the rivets out from under it. My 98 has them and prob years 97-99 have them. First of all why do you need to remove the seats or middle seat?
Old Dec 10, 2011 | 09:36 AM
mgaither0's Avatar
mgaither0
My drivers seat is all caved in from the fat *** that owned it before me. Besides it being extremly uncomfortable it also failed state inspection as one of the metal bars is showing. So I wanted to just replace the drivers seat. But if I come across all 3 in good shape I will replace them.
Old Dec 10, 2011 | 11:06 AM
98DAKAZ's Avatar
98DAKAZ
Default take to a shop
Take to an auto upholstery shop they can probably redo the one seat for you in the truck
Old Dec 10, 2011 | 03:54 PM
mgaither0's Avatar
mgaither0
yeah for $175 just for the drivers seat cushion. So I figure I mite as well get a seat from the junkyard
