Output Speed Sensor Circuit Malfunction. Help please!
Old Dec 13, 2011 | 09:41 PM
Freddy Fog's Avatar
Freddy Fog
Unhappy Output Speed Sensor Circuit Malfunction. Help please!
Hello Dodge Forum,
I'm having a bit of an issue with my Dakota right now. It's a 2000 Dodge Dakota 4x4 with the 4.7 V8 engine. I was on my way to school on Friday when I noticed that something didn't feel quite right with my gearing. It had a hard, powerless shift around 20 mph at about 2300 RPMs and even if I floored the gas, the engine felt like it had no power. Half way to school, my engine light kicks on. By the time I got home and checked the code, it read "Output Speed Sensor Circuit Malfunction" and the code was "PO720" (or P0720, depending on how you read it). I looked all over the net and I've found various solutions to the problem, but none of them seem to answer a question I need to know.
From what I've read, There is a sensor that needs to be changed on the driver's side of the tranny (which we replaced), but even after the code was reset and we did a hard reset of the PCM, the truck still has the issue and the light still kicks on. I'm wondering if we did the wrong fix, if it takes time for the computer to realize the sensor is correct, or what I have to do. I'd be very grateful if someone could help me somehow. Thank you very much.
A side note- I read that everything gets funky with the truck if you drive 50 MPH or above. I take a route to school that has a speed limit of 40 MPH, so I haven't actually had to deal with that myself.
Old Dec 14, 2011 | 06:55 AM
bwdakrt's Avatar
bwdakrt
Maybe this will help.
Old Dec 15, 2011 | 06:11 PM
Freddy Fog's Avatar
Freddy Fog
bwdakrt, thank you SO much for this diagram! I didn't know that there was an input AND output sensor. Might sound boneheaded, but I don't know much about anything. Because of you, my dad and I were able to find the correct part to replace. Worked like a charm. Erased the engine light just because I didn't want to see it anymore. My Dakota is back and anything without a Dodge name had better stay out of the way. Thank you again. B)
Old Dec 15, 2011 | 06:24 PM
bwdakrt's Avatar
bwdakrt
No problem Freddy. Glad I was able to help.
