oil psi
Old Dec 20, 2011 | 03:41 PM
rich1374670x's Avatar
rich1374670x
Default oil psi
I started driving my car more frequently a couple of years ago. My 03 Dakota with the 4.7 didn't see much use. I would run it 1/2 times a week but not always. Sometimes, or if it sat for a while when I would start it, it said check gauges. I would shut it off and restart it and it was fine. The gauge would read 0 and on the second start be normal. I sold my car and this is my daily driver again. It has been fine but twice last week it read 0 and said check gauges. When it ran at 0 psi, no strange noises or such. Really didn't let it run too lpng either. 125,000 miles, regular cab sport 4x4. Any thoughts? I have owned since new, thanks.
Old Dec 20, 2011 | 03:45 PM
bwdakrt's Avatar
bwdakrt
How long since an oil and filter change and what brands & weight are you using?
Could also be a bad oil pressure switch causing the problem.
Old Dec 20, 2011 | 04:36 PM
rich1374670x
1,500 miles ago, Mobil 1 0w30
Old Dec 20, 2011 | 05:05 PM
bwdakrt's Avatar
bwdakrt
Then I'd definitely think about replacing the oil pressure switch. It's located just above the oil filter.
