Cabin air distribution/selector?
Old Jan 5, 2012 | 08:46 PM
KingAirDriver's Avatar
KingAirDriver
Default Cabin air distribution/selector?
Good evening, everyone.
I have a 2001 Dakota Sport, Quad Cab and 4.7L. I'm not sure exactly what it's technically called, but my "airflow distribution ****," for the purposes of this discussion, is not distributing air properly. The only positions that work/blow air from are from the upper vents and defrost. I can't get anything to come out from under the dash.
Any ideas?
(I guess while we're on the subject, the fan speed only blows on a couple of the settings. One or two are unresponsive. Actually, I can get Low, one of the two middles, and the High settings.)
Thanks in advance!
Old Jan 5, 2012 | 09:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
Fan speed - blower motor resistor. It's a common problem and the connector frequently melts. Look up under the dash, passenger side.
HVAC - check by the accelerator pedal, there is an actuator there and some ducting. It's really easy to get knocked off or damaged.
Old Jan 5, 2012 | 09:56 PM
KingAirDriver
Cool, thanks!
Will check on that...after I fix the power window that broke today.
