03 dakota 3.9 4x4
Old Jan 17, 2012 | 07:34 PM
jswank's Avatar
jswank
Default 03 dakota 3.9 4x4
My check engine light keeps coming on.An I had a scanner put on it an it said a vacuum leak.I have replaced the gas cap an I found a line that was cracked.But the light keeps coming back on after a day or two. Do you guys have any ideas were the leak could be? Thanks
Old Jan 17, 2012 | 08:43 PM
bpark8824's Avatar
bpark8824
Did you repair the line that was cracked?
Old Jan 17, 2012 | 11:05 PM
jswank's Avatar
jswank
Yes I replaced the line an it still comes on.
Old Jan 18, 2012 | 08:16 AM
Ts610's Avatar
Ts610
If you have an evap code. I had the same thing happen recently to my 03 4x4. As many have said here in the past check the hose under the drivers side running into the charcoal canister. At first glance mine did not appear cracked. I pulled it off and on the top of the hose it was split. I replaced it and the code has not returned since. Another thing to check is under the hood. There is a hose running from the purge solenoid to the front of the throttle body. I also found this one completely disconnected and split on 2 different places. That one did not fix the evap after fixing but it wouldn't hurt to check.
Old Jan 19, 2012 | 08:51 PM
jswank's Avatar
jswank
Ts610 dos that other line that gos into the canister have that t adapter with the cap on it. I looked at that line an the line from the t with the cap on it to the canister it has a crack ganna replace that an c if that works but first got to get my durango running first.
Old Jan 20, 2012 | 07:11 AM
Ts610's Avatar
Ts610
The line that I found was cracked did not have a t adapter on it. It ran from the canister and got smaller as it ran to hard plastic hose about a foot toward the front of the truck. The end on the canister is larger so you may have to go to oreillys and grab adapters to make it work.
