New dakota owner, Knock Knock
Old Feb 6, 2012 | 08:52 PM
TwoDoorDime's Avatar
TwoDoorDime
Well the truck fired up first crank, oil pressure went to 40 psi...Im happy. I have a bit of an exhaust leak though. I painted the engine a bronze gun metal type color. I wrinkle blacked the valve covers, and painted the intake manifold silver. Is there a way to adjust the clutch release point? Mine is very high, the clutch is brand new. I drove the truck around the block and everything seems normal but i wont know until a couple more road tests, BOY AM I EXCITED! It took me a total of about 14 hours from start to finish.
Old Feb 6, 2012 | 11:09 PM
Bolo1816phidelt's Avatar
Bolo1816phidelt
Welcome to the forum! And also, that's the exact truck I could never find. Gotta love the v8 with the 5.2 Good luck! Let us know how it turns out!
Old Feb 7, 2012 | 12:00 AM
Trent479's Avatar
Trent479
Truck looks good! And dang your movin fast! Good job!
Old Feb 7, 2012 | 10:46 AM
UWAdventurer's Avatar
UWAdventurer
Welcome, any photos of the finished product?
Old Feb 7, 2012 | 11:46 AM
gnelson49's Avatar
gnelson49
I am not aware of any way to adjust the clutch release point as it is a hydraulic system. My clutch releases high as well, but it is about gone. Not sure what it will be like when rebuilt. Might make sure the system is well bled of air, those hydraulic clutches are a bear to get all the air out of without a vac pump or a helper.
Old Feb 7, 2012 | 04:45 PM
TwoDoorDime
THANKS GUYS!! I took pictures but cannot post them until tonight. I put 20 miles on it so far. I'm very happy with the way it runs minus a little grinding while shifting. I'm going to drain it and put in whatever it requires plus some gm synchromesh fluid. Ive used in my Hondas road race transmissions and it makes them shift like butter. Look for pics tonight!
Old Feb 7, 2012 | 05:04 PM
chris1996's Avatar
chris1996
that's good to hear that everything goes like planned
Old Feb 8, 2012 | 12:32 AM
TwoDoorDime
Just finished adding coolant to her. WOOOOT
Old motor, ive never seen so much sludge and crap inside a motor.
Just the back
Pic of motor. Still have a ton of crap to clean up with degreaser. The block is spotless, valve covers repainted, intake mani, alternator, and bracket. I still need to clean the a/c compressor and get a k&n intake (or similar)
